跳转到主内容
Dell Inspiron 15 7579 Wifi Card Replacement
Inaki Madrigal
Inaki Madrigal4 其他贡献者
最后更新于 May 7, 2024
15 - 20 分钟
中等
This guide will walk you through the process to remove and replace the wifi internet card in your Dell Inspiron 15 7579.
你所需要的
工具
查看更多...
  1. Dell Inspiron 15 7579 Wifi Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Wifi Card Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15 7579 Wifi Card Replacement: 步骤 2 中的图像 2,2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Wifi Card Replacement, Wifi Card: 步骤 3 中的图像 1,1
    • Remove the bracket holding the card in place by unscrewing the single 3 mm screw located in the upper left hand corner of the device using a Phillips #1 screwdriver bit.
  4. Dell Inspiron 15 7579 Wifi Card Replacement: 步骤 4 中的图像 1,1
    • Pull the Wi-Fi card out of the connector slot.
  5. Dell Inspiron 15 7579 Wifi Card Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the two connector pins from the wifi card using tweezers.
    • During reassembly, the pins require some finesse to fit them back onto the card. It will take time to put back on. Be sure to line up the socket on the cable to the pin socket on the card.
结论
Inaki Madrigal
于04/23/18注册
775 声望
创作了6篇指南
团队
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G9
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 48
总计 4,023
