跳转到主内容
Dell Inspiron 15 7579 Speakers Replacement
Inaki Madrigal
Inaki Madrigal6 其他贡献者
最后更新于 May 7, 2024
10 - 15 分钟
中等
特色学生指南
Before replacing the speakers, we recommend starting out with our troubleshooting guide. If you are still having problems, follow the steps below to replace your speakers.
你所需要的
工具
查看更多...
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement: 步骤 2 中的图像 2,2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: 步骤 4 中的图像 1,1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement: 步骤 6 中的图像 2,2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: 步骤 7 中的图像 1,1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement: 步骤 8 中的图像 2,2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 15 7579 Speakers Replacement: 步骤 9 中的图像 2,2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
结论
Inaki Madrigal
于04/23/18注册
775 声望
创作了6篇指南
团队
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G9
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 1,294
