跳转到主内容
Dell Inspiron 15 7560 Display Assembly Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 August 14, 2022
9 - 15 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Display Assembly.
你所需要的
工具
  1. Dell Inspiron 15 7560 Display Assembly Replacement, Note the Routing: 步骤 1 中的图像 1,1
  2. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Latch: 步骤 2 中的图像 1,1
    • Open the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Display: 步骤 3 中的图像 1,1
    • Open the display at an angle of 90 degrees.
  4. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Computer: 步骤 4 中的图像 1,1
    • Place the computer on the edge of a table so that the palm rest and keyboard assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  5. Dell Inspiron 15 7560 Display Assembly Replacement, Remove the Screws: 步骤 5 中的图像 1,1
    • Remove the four screws (M2.5x5) that secure the display hinges to the palm rest and keyboard assembly.
  6. Dell Inspiron 15 7560 Display Assembly Replacement, Lifting the Display Assembly: 步骤 6 中的图像 1,1
    • Lift the display assembly off the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Assembly: 步骤 7 中的图像 1,1
    • Place the palm rest and keyboard assembly on the edge of a table with the keyboard facing down.
  8. Dell Inspiron 15 7560 Display Assembly Replacement, Align the Screw Holes: 步骤 8 中的图像 1,1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 7560 Display Assembly Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • Replace the four screws (M2.5x5) that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Display Assembly Replacement, Close the Display: 步骤 10 中的图像 1,1
    • Close the display and turn the computer over.
  11. Dell Inspiron 15 7560 Display Assembly Replacement, Sliding the Display Cable: 步骤 11 中的图像 1,1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  12. Dell Inspiron 15 7560 Display Assembly Replacement, Routing the Antenna Cables: 步骤 12 中的图像 1,1
    • Route the antenna cables through the routing guides on the fan.
终点
2等其他人完成本指南。
Terrence15
于12/18/17注册
79,549 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,010
