跳转到主内容
Dell Inspiron 15 7560 Battery Replacement
Terrence15
Terrence152 其他贡献者
最后更新于 August 24, 2022
7 - 15 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Battery.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Dell Inspiron 15 7560 Battery Replacement, Disconnect the Battery Cable: 步骤 1 中的图像 1,1
  2. Dell Inspiron 15 7560 Battery Replacement, Peel the Tape: 步骤 2 中的图像 1,1
    • Peel the tape that secures the hard-drive cable to the battery.
  3. Dell Inspiron 15 7560 Battery Replacement, Open the Latch: 步骤 3 中的图像 1,1
    • Open the latch and disconnect the hard-drive cable from the system board.
  4. Dell Inspiron 15 7560 Battery Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 7560 Battery Replacement, Lifting the Battery: 步骤 5 中的图像 1,1
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Inspiron 15 7560 Battery Replacement, Align the Screw Holes: 步骤 7 中的图像 1,1
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Battery Replacement, Replace the Screws: 步骤 8 中的图像 1,1
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  8. Dell Inspiron 15 7560 Battery Replacement, Sliding the Hard Drive Cable: 步骤 9 中的图像 1,1
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the cable.
  9. Dell Inspiron 15 7560 Battery Replacement, Adhering the Tape: 步骤 10 中的图像 1,1
    • Adhere the tape that secures the hard-drive cable to the battery.
  10. Dell Inspiron 15 7560 Battery Replacement, Connect the Battery Cable: 步骤 11 中的图像 1,1
    • Connect the battery cable to the system board.
终点
3等其他人完成本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 19
总计 4,693
