跳转到主内容
Dell Inspiron 15 5577 Gaming Fans Replacement
Julia Cabral
Julia Cabral4 其他贡献者
最后更新于 January 2, 2024
25分钟 - 1小时
中等
需要更好的图片
When your Dell laptop starts overheating or making strange fan noises, it may be time to consider a fan replacement. This replacement will improve heating issues, and protect your laptop from potential harm. Basic hardware skills are a must, along with having a gentle touch to navigate the disassembly process. Successfully swapping out the fan requires careful precision, making this repair a rewarding yet complex task for your Dell Inspiron 15 5577.
你所需要的
工具
  1. Dell Inspiron 15 5577 Gaming Fans Replacement, Fans: 步骤 1 中的图像 1,1
    • Unscrew the base cover plate to locate the gaming fan.
  2. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 2 中的图像 1,1
    • Remove the base cover.
  3. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 3 中的图像 1,1
    • Gently tug on the battery cable in order to disconnect it from the motherboard.
  4. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 4 中的图像 1,1
    • Loosen the screws that secure the battery in place.
  5. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 5 中的图像 1,1
    • Carefully pull the battery out of the laptop.
  6. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 6 中的图像 1,1
    • Remove the cable above the hard drive.
  7. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 7 中的图像 1,1
    • Loosen the screws that secure the hard drive.
  8. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the hard drive.
  9. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 9 中的图像 3,3
    • Flip the laptop over and open the lid.
    • Remove the palm rest.
  10. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 10 中的图像 1,1
    • Carefully unsecure the rest of the shell on the base of the computer.
  11. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 11 中的图像 1,1
    • Remove the keyboard.
  12. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 12 中的图像 1,1
    • Loosen the screws securing the metal plate and contents of the base.
  13. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 13 中的图像 1,1
    • Remove the plate.
  14. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 14 中的图像 1,1
    • Unscrew and remove the first fan from the base of the laptop.
  15. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 15 中的图像 1,1
    • Remove the fan's cable from the board.
  16. Dell Inspiron 15 5577 Gaming Fans Replacement: 步骤 16 中的图像 1,1
    • Repeat steps 14 and 15 for the remaining fan.
结论
4等其他人完成本指南。
Julia Cabral
于10/31/19注册
403 声望
创作了2篇指南
团队
UMass Dartmouth, Team S2-G7, Barthe Fall 2019 UMass Dartmouth, Team S2-G7, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G7
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 48
总计 2,416
