跳转到主内容
Dell Inspiron 15 3567 Hard Drive Replacement
Terrence15
Terrence152 其他贡献者
最后更新于 January 22, 2020
2 - 9 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Hard Drive.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Dell Inspiron 15 3567 Hard Drive Replacement, Open the Latch: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Lift the hard-drive assembly off the palm-rest assembly.
  4. Dell Inspiron 15 3567 Hard Drive Replacement, Disconnect the Interposer: 步骤 4 中的图像 1,1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 3567 Hard Drive Replacement, Remove the Screws: 步骤 5 中的图像 1,1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 3567 Hard Drive Replacement, Lifting the Hard Drive: 步骤 6 中的图像 1,1
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15 3567 Hard Drive Replacement, Align the Screw Holes: 步骤 7 中的图像 1,1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: 步骤 8 中的图像 1,1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 3567 Hard Drive Replacement, Connect the Interposer: 步骤 9 中的图像 1,1
    • Connect the interposer to the hard drive.
  10. Dell Inspiron 15 3567 Hard Drive Replacement, Placing the Hard-Drive Assembly: 步骤 10 中的图像 1,1
    • Place the hard-drive assembly in the palm-rest assembly and align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  11. Dell Inspiron 15 3567 Hard Drive Replacement, Replace the Screws: 步骤 11 中的图像 1,1
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  12. Dell Inspiron 15 3567 Hard Drive Replacement, Sliding the Hard Drive Cable: 步骤 12 中的图像 1,1
    • Slide the hard-drive cable into its connector on the system board and close the latch to secure the cable.
    Step one seems to start with a disassembled computer. No information on how to get the back off the laptop (despite removing all screws, there’s no obvious way to separate the back).
    Lewis Butler - 回复
    This guide is not complete at all. To access the hard drive you first need to remove the DVD player, the keyboard and then the back plate.
    Olomorn - 回复
终点
3等其他人完成本指南。
Terrence15
于12/18/17注册
79,585 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
5指南评论
My Dell Inspiron 15 3567 has a bottom cover which I STRONGLY suggest be removed after REMOVING THE BATTERY.
IMHO Those are important steps - their omission makes me lose any credibility for your site.
[deleted] - 回复
The steps that need to be PRIOR to this guide are to remove the keyboard first, disconnect the keyboard cable, remove the 5 screws under the keyboard attaching the plastic to the motherboard. Then turn over the laptop, remove some 12 screws or so, remove the battery, remove the DVD drive, then separate the bottom case from the rest of the laptop carefully.
Thomas Dillon - 回复
This guide is utterly useless and it neglects all the steps to get the actual bottom cover off to access the hard drive assembly. Zero stars.
pamadeus - 回复
This guide is totally incomplete. It doesn't show how to access the drive in the first place. This guide should be taken down.
DarkAthena - 回复
This guide is useless. I condemn the author for posting such an incomplete guide.
Scyth3934 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 39
总计 12,358
