跳转到主内容
Dell Inspiron 15 3565 Memory Module Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 22, 2019
25秒 - 1分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Memory Module.
  1. Dell Inspiron 15 3565 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3565 Memory Module Replacement, Removing the Memory Module: 步骤 2 中的图像 1,1
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 3565 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 1,1
    • Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3565 Memory Module Replacement, Installing the Memory Module: 步骤 4 中的图像 1,1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,585 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
1指南评论
What Laptop is this for? I guess the disassembly must be somewhere else.
Don Minish - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 914
