跳转到主内容
Dell Inspiron 13-7373 Battery Replacement
你所需要的
  1. Dell Inspiron 13-7373 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 13-7373 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 13-7373 Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 13-7373 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the laptop.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
14等其他人完成本指南。
John Egan
于10/25/19注册
485 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G4
3 名成员
创作了5篇指南
6指南评论
can you recommend a battery model #? I want to be certain I buy the correct one.
Peter Zinsli - 回复
The first step needs to be amended. There are 10 back cover screws including the central one, not 9. Additionally, the battery cable removes outward from the battery, not upward.
Mike Vandenberg - 回复
Hi Mike,
Thanks for the feedback! I’ll make the corrections you suggested.
Arthur Shi -
I'm told that you should replace the connector cable that connects the battery to the motherboard whenever you replace the battery. However that cable doesn't come with the kit. How do I get that part?
Bill Knapp - 回复
I found that I had to remove the back of the laptop from the touchpad side of laptop first, not the hinge side first as indicated in the pictures.
Rich Hunt - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 72
总计 16,927
