跳转到主内容
Dell Inspiron 13-7352 System Board Replacement
Chris Monte
Chris Monte7 其他贡献者
最后更新于 August 1, 2024
10分钟
中等
需要更好的图片
This guide will show users through the steps required to replace the main system board.
你所需要的
配件
工具
查看更多...
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7352 System Board Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7352 System Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-7352 System Board Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 步骤 4 中的图像 1,3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 步骤 4 中的图像 2,3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 步骤 4 中的图像 3,3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: 步骤 5 中的图像 1,1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: 步骤 6 中的图像 1,3 Dell Inspiron 13-7352 System Board Replacement, System Board: 步骤 6 中的图像 2,3 Dell Inspiron 13-7352 System Board Replacement, System Board: 步骤 6 中的图像 3,3
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: 步骤 7 中的图像 1,1
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: 步骤 8 中的图像 1,1
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 13-7352 System Board Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 13-7352 System Board Replacement: 步骤 9 中的图像 3,3
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 13-7352 System Board Replacement: 步骤 10 中的图像 2,2
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: 步骤 11 中的图像 1,1
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
结论
3等其他人完成本指南。
Chris Monte
于09/30/15注册
411 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 24
总计 1,892
