需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片!
简介
转到步骤 1 ↓This guide will show users through the steps required to replace the main system board.
你所需要的
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Locate your memory module (RAM).
Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
Remove cord that runs from system board to the I/O board.
Remove connecting wire that runs from fan to system board.
3等其他人完成本指南。
