跳转到主内容
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Chase Sparkman
Chase Sparkman6 其他贡献者
最后更新于 August 1, 2024
5分钟
非常容易
需要更好的图片
The Memory Module (RAM) is one of the two memory storage places in your laptop. Some of your laptop's speed is dependent on the Memory Module so an upgrade may boost your laptop's overall performance if your current one if full.
你所需要的
工具
查看更多...
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 1,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 2,3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): 步骤 4 中的图像 3,3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: 步骤 5 中的图像 1,1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
结论
4等其他人完成本指南。
Chase Sparkman
于09/30/15注册
512 声望
创作了2篇指南
团队
4指南评论
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - 回复
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - 回复
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - 回复
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 3,316
