跳转到主内容
Dell Inspiron 13-7347 Touchpad Replacement
lee120496
lee1204962 其他贡献者
最后更新于 June 13, 2019
15分钟
中等
This guide will assist you to replace a new touchpad to of your Dell Inspiron 13-7347. Make sure the touchpad that you are replacing is specifically for Dell Inspiron 13-7347. It's very important to find the correct model of touchpad for your Dell Inspiron 13-7347 in order to prevent any troubles. Be sure to use the tools we suggested, and be gentle when you are using the screwdriver. Its very easy to lead to stripped screws if you didn't use the screwdriver correctly or not gentle enough.
Make sure to follow the instructions step by step carefully.
你所需要的
  1. Dell Inspiron 13-7347 Touchpad Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 3 中的图像 3,3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: 步骤 5 中的图像 1,2 Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: 步骤 5 中的图像 2,2
    • Unplug the sliding connector.
    • The cord is extremely fragile.
  6. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 6 中的图像 3,3
    • Flip the cord upward.
  7. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 7 中的图像 2,2
    • Remove the four 2.5 mm JIS #00 screws.
  8. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 8 中的图像 3,3
    • Flip the metal plate upward.
    • Take out the metal plate completely.
  9. Dell Inspiron 13-7347 Touchpad Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 13-7347 Touchpad Replacement: 步骤 9 中的图像 3,3
    • Remove the touchpad by lifting up the handle.
结论
lee120496
于02/05/19注册
643 声望
创作了4篇指南
团队
UC Davis, Team S20-G8, Lore Winter 2019 UC Davis, Team S20-G8, Lore Winter 2019 的会员
UCD-LORE-W19S20G8
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 23
总计 565
