跳转到主内容
Dell Inspiron 13-7347 Hard Drive Replacement
Kyle Smith
Kyle Smith5 其他贡献者
最后更新于 May 3, 2021
10分钟
简单
不正确的工具
This guide will show you how to remove and replace the hard drive from a Dell Inspiron 13-7347.
Before you begin, power off the system and unplug all external devices and power sources including the AC adapter.
Before the laptop is opened, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface during the process to prevent electrostatic discharge (ESD).
你所需要的
  1. Dell Inspiron 13-7347 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13-7347 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13-7347 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7347 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 801
