跳转到主内容
Dell Inspiron 13 7378 RAM Replacement
Emma Simon
Emma Simon2 其他贡献者
最后更新于 May 26, 2022
5 - 10 分钟
简单
Many users of the Dell Inspiron 13 7378 complain about its slow processing speed. One way to increase processing speed is adding more RAM. This guide will show you exactly how to do that. The RAM compartment in this device has two slots. When you purchase your device, it comes with one slot full and one slot empty. Following this guide will allow you to either replace your existing stick, or add a second one.
你所需要的
工具
查看更多...
  1. Dell Inspiron 13 7378 RAM Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13 7378 RAM Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 RAM Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13 7378 RAM Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13 7378 RAM Replacement: 步骤 3 中的图像 3,3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 RAM Replacement, RAM: 步骤 4 中的图像 1,3 Dell Inspiron 13 7378 RAM Replacement, RAM: 步骤 4 中的图像 2,3 Dell Inspiron 13 7378 RAM Replacement, RAM: 步骤 4 中的图像 3,3
    • To remove a RAM stick, gently pull apart the metal tabs on either side of the stick.
    • Carefully grasp the stick on its side and pull it out.
    • The plastic sheet covering the RAM compartment depicts the process.
  5. Dell Inspiron 13 7378 RAM Replacement: 步骤 5 中的图像 1,1
    • When inserting the new stick, make sure that the gap on in the stick aligns with the gap in the slot.
结论
另外一个人完成了本指南。
Emma Simon
于02/08/22注册
165 声望
撰写一个指南
团队
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G3
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 579
