跳转到主内容
Dell Inspiron 11-3164 Mousepad Replacement
Michael Kendziora
Michael Kendziora3 其他贡献者
最后更新于 May 7, 2024
10 - 15 分钟
简单
If your mousepad is working incorrectly, refer to this page's troubleshooting guide. This fix is only necessary after you have attempted the prerequisite fixes.
你所需要的
配件
工具
查看更多...
  1. Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: 步骤 1 中的图像 1,2 Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: 步骤 1 中的图像 2,2
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Mousepad Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3164 Mousepad Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Mousepad Replacement: 步骤 3 中的图像 1,1
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Mousepad Replacement: 步骤 4 中的图像 1,1
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Mousepad Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 11-3164 Mousepad Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 11-3164 Mousepad Replacement: 步骤 5 中的图像 3,3
    • With tweezers, disconnect the keyboard cable
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • Gently remove the mouse touchpad.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 222
