跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 3 Advanced Flight Controller Replacement
你所需要的
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Battery: 步骤 1 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement, Battery: 步骤 1 中的图像 2,2
      • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
      • Remember to disarm and power down your quadcopter before beginning any disassembly.
      询问修复机器人
      添加评论
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 2 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 2 中的图像 2,2
      • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
      • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
      询问修复机器人
      添加评论
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Cover: 步骤 3 中的图像 1,1
      • Turn the Phantom 3 Advanced upside down.
      询问修复机器人
      添加评论
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 4 中的图像 1,1
      • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
      • There is one screw per arm, located at the tip of the arm.
      询问修复机器人
      添加评论
    3. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 5 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 5 中的图像 2,2
      • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
      • There are two 5mm screws on each arm.
      询问修复机器人
      添加评论
    4. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 6 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 6 中的图像 2,2
      • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
      • There is one screw on each arm located near the landing gear.
      询问修复机器人
      添加评论
    5. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 7 中的图像 1,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 7 中的图像 2,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 7 中的图像 3,3
      • Carefully flip the phantom back over with the motors facing up.
      • Peel back the silver stickers from the seam in the cover.
      • Using a plastic spudger, slowly separate the two halves of the plastic shell.
      • This step requires some force, and the plastic will click loudly as the shell separates.
      • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
      询问修复机器人
      添加评论
    6. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 8 中的图像 1,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 8 中的图像 2,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 8 中的图像 3,3
      • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
      • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
      • Press the tab on the side of the connector and pull up on the cable.
      • Continue to remove the shell the rest of the way.
      添加评论
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Flight Controller: 步骤 9 中的图像 1,1
      • Locate the five ribbon cables that need to be disconnected from the control board.
      • Locate the red and black battery wires.
      • Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
      询问修复机器人
      添加评论
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 10 中的图像 1,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 10 中的图像 2,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 10 中的图像 3,3
      • Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
      • Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
      • Desolder the battery wires.
      询问修复机器人
      添加评论
    3. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 11 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 11 中的图像 2,2
      • Remove the cable next to where the battery wires were connected. Pinch and hold the top of the connector, then pull it out.
      询问修复机器人
      添加评论
    4. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 12 中的图像 1,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 12 中的图像 2,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 12 中的图像 3,3
      • Remove the black ribbon cable and the 3-wire cable next to it. Press the small tab on the ribbon cable connector and pull it out.
      询问修复机器人
      添加评论
    5. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 13 中的图像 1,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 13 中的图像 2,3 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 13 中的图像 3,3
      • Locate the ribbon cable that is next to the word "Front" on the flight controller.
      • Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
      • Remove the black band from the ribbon cable.
      • Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
      询问修复机器人
      添加评论
    6. DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 14 中的图像 1,2 DJI Phantom 3 Advanced Flight Controller Replacement: 步骤 14 中的图像 2,2
      • Remove the four 6.5mm long 2mm screws with a philips head 00 screwdriver.
      • Remove the flight controller now by slowly pulling if off of the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G2
3 名成员
创作了36篇指南
2指南评论
Very clear and helpful. Thank You.
Herb - 回复 分享
Excellent with great visuals. Can really see what to do
Leo Miller - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 54
总计 8,165
