跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 2 Vision+ ESC Removal
你所需要的
  1. DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 步骤 1 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 步骤 1 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Remove the battery: 步骤 1 中的图像 3,3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ ESC Removal, Propellers: 步骤 2 中的图像 1,1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 3,3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 3,3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: 步骤 5 中的图像 1,2 DJI Phantom 2 Vision+ ESC Removal, Case Top Shell: 步骤 5 中的图像 2,2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. DJI Phantom 2 Vision+ ESC Removal: 步骤 6 中的图像 1,2 DJI Phantom 2 Vision+ ESC Removal: 步骤 6 中的图像 2,2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  7. DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 步骤 7 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 步骤 7 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Unplug GPS connector and remove case: 步骤 7 中的图像 3,3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
  8. DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: 步骤 8 中的图像 1,2 DJI Phantom 2 Vision+ ESC Removal, Desolder motor wires: 步骤 8 中的图像 2,2
    • Desolder all three motor wires.
    • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
    • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
  9. DJI Phantom 2 Vision+ ESC Removal: 步骤 9 中的图像 1,1
    • Remove the four 2mm hex motor bolts.
  10. DJI Phantom 2 Vision+ ESC Removal: 步骤 10 中的图像 1,2 DJI Phantom 2 Vision+ ESC Removal: 步骤 10 中的图像 2,2
    • Remove the motor from the motor mount.
  11. DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 步骤 11 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 步骤 11 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Prepare ESC for removal: 步骤 11 中的图像 3,3
    • Cut the zip-tie securing the signal and power cables.
    • Unplug the ESC signal cable molex connector from the ESC.
  12. DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: 步骤 12 中的图像 1,2 DJI Phantom 2 Vision+ ESC Removal, Desolder the ESC: 步骤 12 中的图像 2,2
    • Desolder the ESC ground and voltage wires from the mainboard.
    • Be careful not to melt the plastic case bottom shell with your soldering iron or damage any electronic components.
    • You can remove in-the-way cables by unplugging them and moving them aside. This will protect them from the warning above.
    • Be sure to plug these cables back in before reassembling your Phantom 2.
  13. DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 步骤 13 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 步骤 13 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Unsecuring the ESC: 步骤 13 中的图像 3,3
    • Remove the two ESC securing screws.
    • The clear plastic LED cover will either drop from the underside or need to be loosened with a plastic spudger.
  14. DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 步骤 14 中的图像 1,3 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 步骤 14 中的图像 2,3 DJI Phantom 2 Vision+ ESC Removal, Removing the ESC: 步骤 14 中的图像 3,3
    • With the ESC no longer secured to the airframe, lift it up and remove it.
结论
8等其他人完成本指南。
David Hoyt
于04/09/10注册
4,053 声望
创作了41篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了61篇指南
1指南评论
Is it a difference between ESC from different versions (1.0, 2.0 and 3.0) of Phantom 2?
jarbas_sjo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 6,746
