简介
The motherboard is the internal component of your router that performs all basic functioning. It is the most important part of your device. If your device is non operational, your motherboard most likely needs to be replaced. Follow this guide for instructions on how to do so.
你所需要的
Begin by placing the wired router face down.
Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
Using a plastic opening tool, trace the edges of the router on all sides. Gently pry the device until it eventually snaps open.
Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
Locate the two screws at the bottom of the logic board.
Using the same PH2 head on your Philips screwdriver, unscrew these screws.
Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
You have now removed the logic board from your device.
另外一个人完成了本指南。
