跳转到主内容
CyberHome CH-DVD 300 Disc Tray Bracket Replacement
Chris Menezes
Chris Menezes5 其他贡献者
最后更新于 June 3, 2014
15分钟
简单
特色学生指南
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
你所需要的
工具
  1. CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Top Panel: 步骤 1 中的图像 1,2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Top Panel: 步骤 1 中的图像 2,2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Disc Tray Bracket Replacement: 步骤 2 中的图像 1,2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement: 步骤 2 中的图像 2,2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Disc Tray Bracket: 步骤 3 中的图像 1,2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Disc Tray Bracket: 步骤 3 中的图像 2,2
    • Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
  4. CyberHome CH-DVD 300 Disc Tray Bracket Replacement: 步骤 4 中的图像 1,2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement: 步骤 4 中的图像 2,2
    • Lift up on the bracket by:
    • Sliding the disc tray bracket forward.
    • Lifting the back edge up.
结论
4等其他人完成本指南。
Chris Menezes
于04/07/14注册
654 声望
创作了5篇指南
团队
Cal Poly, Team 6-5, Forte Spring 2014 Cal Poly, Team 6-5, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 4,260
