跳转到主内容
Cricut Maker Motherboard Replacement
Devyn White
Devyn White5 其他贡献者
最后更新于 February 8, 2025
2 - 3 小时
困难
需要更好的图片
需要更多图片
The motherboard of a Cricut Maker device is the machine's control panel.
Follow this guide to fix a Cruit Maker motherboard. You may need to replace the motherboard if your device's cutter or USB port malfunctions. The power button turning red immediately after plugging in the machine may also indicate a faulty motherboard.
The motherboard and the parts surrounding it are delicate and should be handled with care.
Note: Before beginning this repair, turn off the device and unplug it from the outlet.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 步骤 1 中的图像 1,3 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 步骤 1 中的图像 2,3 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 步骤 1 中的图像 3,3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Motherboard Replacement: 步骤 2 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Motherboard Replacement: 步骤 3 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 3 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 3 中的图像 3,3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Motherboard Replacement: 步骤 4 中的图像 1,1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Motherboard Replacement, Front Door Replacement: 步骤 5 中的图像 1,2 Cricut Maker Motherboard Replacement, Front Door Replacement: 步骤 5 中的图像 2,2
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Motherboard Replacement: 步骤 6 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 6 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Motherboard Replacement: 步骤 7 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 7 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 7 中的图像 3,3
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Motherboard Replacement: 步骤 8 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 8 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 8 中的图像 3,3
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Motherboard Replacement: 步骤 9 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Motherboard Replacement: 步骤 10 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 10 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 10 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Motherboard Replacement: 步骤 11 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 11 中的图像 2,2
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Motherboard Replacement: 步骤 12 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 12 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Motherboard Replacement: 步骤 13 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 13 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 13 中的图像 3,3
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Motherboard Replacement: 步骤 14 中的图像 1,3 Cricut Maker Motherboard Replacement: 步骤 14 中的图像 2,3 Cricut Maker Motherboard Replacement: 步骤 14 中的图像 3,3
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Motherboard Replacement, Motherboard Replacement: 步骤 15 中的图像 1,3 Cricut Maker Motherboard Replacement, Motherboard Replacement: 步骤 15 中的图像 2,3 Cricut Maker Motherboard Replacement, Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the five 7 mm screws from the motherboard.
  16. Cricut Maker Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the gray electrical tape from the cables.
  17. Cricut Maker Motherboard Replacement: 步骤 17 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 17 中的图像 2,2
    • Unplug both cables from the corners of the motherboard by pulling them upwards from the base of the connectors.
  18. Cricut Maker Motherboard Replacement: 步骤 18 中的图像 1,2 Cricut Maker Motherboard Replacement: 步骤 18 中的图像 2,2
    • Gently slide the motherboard out from USB port slot to remove it from the device.
结论
4等其他人完成本指南。
Devyn White
于09/20/22注册
1,131 声望
创作了5篇指南
团队
6条评论
So do you sell the motherboard or know where it buy one for cricut cxpl301
David Washington - 回复
I too am looking for a replacement board. It was suggested to me that I could contact one of the pcb repair companies. For a fee, they will either check and repair your board or they will copy and print a new board and mail it back to you. You have to send in your board for them to check and copy though. So I guess reputation and reviews would be priority. It would suck to send our boards off and never receive a new one or the old one. :-/.
Jennifer Daniels -
Cricut does not sell parts. Cricut does not do repairs.
B·Ware - 回复
sooooo, theres no place to get parts? thats stupid...might as well just through it away then...
Kirk Serbian - 回复
Bonjour pourriez vous nous dire où trouver la carte mère svp
Magali Magnier - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 82
过去 30 天: 297
总计 8,546
