当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before starting repairs, take your watch off the charger and power it down.
Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
Don’t worry about removing the screws, they will stay in place in the back cover.
Insert an opening tool between the back cover and the metal housing.
Twist the opening tool to create a wider gap.
Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
The core's plastic frame fits tightly within the watch's metal housing.
Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
Twist and tilt the spudger to lever the core assembly out of the metal housing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
