跳转到主内容
加入维修社区 - 创建账户
Core Assembly Removal
你所需要的
  1. Core Assembly Removal, Unfasten the back cover screws: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    添加评论
  2. Core Assembly Removal, Wedge open the back cover: 步骤 2 中的图像 1,2 Core Assembly Removal, Wedge open the back cover: 步骤 2 中的图像 2,2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    添加评论
  3. Core Assembly Removal, Disconnect the sensor flex cable: 步骤 3 中的图像 1,3 Core Assembly Removal, Disconnect the sensor flex cable: 步骤 3 中的图像 2,3 Core Assembly Removal, Disconnect the sensor flex cable: 步骤 3 中的图像 3,3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    询问修复机器人
    添加评论
  4. Core Assembly Removal, Remove the back cover: 步骤 4 中的图像 1,2 Core Assembly Removal, Remove the back cover: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    添加评论
  5. Core Assembly Removal, Unplug the display connector: 步骤 5 中的图像 1,2 Core Assembly Removal, Unplug the display connector: 步骤 5 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
    询问修复机器人
    添加评论
  6. Core Assembly Removal, Loosen the core assembly: 步骤 6 中的图像 1,2 Core Assembly Removal, Loosen the core assembly: 步骤 6 中的图像 2,2
    • The core's plastic frame fits tightly within the watch's metal housing.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    询问修复机器人
    添加评论
  7. Core Assembly Removal, Remove the core assembly: 步骤 7 中的图像 1,3 Core Assembly Removal, Remove the core assembly: 步骤 7 中的图像 2,3 Core Assembly Removal, Remove the core assembly: 步骤 7 中的图像 3,3
    • Carefully thread the display flex cable through the gap on the core's plastic frame.
    • Remove the core assembly.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Tobias Isakeit
于03/31/14注册
133,983 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,151篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 53
总计 1,620
