跳转到主内容
加入维修社区 - 创建账户
Conair Infiniti Pro Model 259NP Cold Shot Button Replacement
你所需要的
    1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      询问修复机器人
      添加评论
    2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 2 中的图像 1,2 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 2 中的图像 2,2
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      询问修复机器人
      添加评论
    3. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 3 中的图像 1,3 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 3 中的图像 2,3 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 3 中的图像 3,3
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      询问修复机器人
      添加评论
    1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Fan Motor Assembly: 步骤 4 中的图像 1,2 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Fan Motor Assembly: 步骤 4 中的图像 2,2
      • Hold the hair dryer by the nozzle so that the handle points to the left.
      • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
      询问修复机器人
      添加评论
    2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 5 中的图像 1,3 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 5 中的图像 2,3 Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 5 中的图像 3,3
      • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
      • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
      • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
      询问修复机器人
      添加评论
    1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Cold Shot Button: 步骤 6 中的图像 1,1
      • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
      • Hold the electrical switches so that the wires are facing upwards.
      询问修复机器人
      添加评论
    2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: 步骤 7 中的图像 1,1
      • Focus on the button closest along the wires to the fan motor.
      • Desolder the button at the circled locations.
      • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Timothy Lo
于04/22/14注册
1,214 声望
创作了7篇指南
团队
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G58
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 44
总计 2,399
