跳转到主内容
Compaq Presario v2000 RAM Replacement
Viscous
Viscous 另一个贡献者
最后更新于 March 7, 2024
30秒 - 2分钟
中等
社区贡献指南
This is a guide on how to replace the RAM for a Compaq Presario V2000.
你所需要的
配件
工具
查看更多...
  1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: 步骤 1 中的图像 1,2 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: 步骤 1 中的图像 2,2
    • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
    • Lift the RAM door up and away.
  2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 步骤 2 中的图像 1,3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 步骤 2 中的图像 2,3 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 步骤 2 中的图像 3,3
    • There are two metal clips holding both RAM modules in place.
    • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
    • Pull the stick of RAM out.
    • Repeat the last 3 steps for the bottom RAM stick.
  3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: 步骤 3 中的图像 1,2 Compaq Presario v2000 RAM Replacement, Installing the new RAM: 步骤 3 中的图像 2,2
    • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
    • Push the RAM in until a click is heard.
    • Repeat the last 2 steps for the top slot.
  4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: 步骤 4 中的图像 1,1
    • Repeat the first part of this guide to reinstall the RAM door.
结论
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
Viscous
于02/02/24注册
379 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 150
