跳转到主内容
加入维修社区 - 创建账户
Coby KYROS MID7125 Side Lock Button Replacement
你所需要的
    1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: 步骤 1 中的图像 1,1
      • Begin by removing back panel using the large opening tool.
      询问修复机器人
      添加评论
    2. Coby KYROS MID7125 Side Lock Button Replacement: 步骤 2 中的图像 1,3 Coby KYROS MID7125 Side Lock Button Replacement: 步骤 2 中的图像 2,3 Coby KYROS MID7125 Side Lock Button Replacement: 步骤 2 中的图像 3,3
      • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
      询问修复机器人
      添加评论
    3. Coby KYROS MID7125 Side Lock Button Replacement: 步骤 3 中的图像 1,1
      • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
      • Review Battery Replacement for details on how to remove battery.
      询问修复机器人
      添加评论
    4. Coby KYROS MID7125 Side Lock Button Replacement: 步骤 4 中的图像 1,2 Coby KYROS MID7125 Side Lock Button Replacement: 步骤 4 中的图像 2,2
      • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
      询问修复机器人
      添加评论
    5. Coby KYROS MID7125 Side Lock Button Replacement: 步骤 5 中的图像 1,1
      • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
      • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
      询问修复机器人
      添加评论
    6. Coby KYROS MID7125 Side Lock Button Replacement: 步骤 6 中的图像 1,1
      • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
      • Reverse steps 1-5 to reassemble.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G2
3 名成员
创作了15篇指南
1指南评论
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 32
总计 497
