跳转到主内容
加入维修社区 - 创建账户
Cineyo BT-03 Device Page Button Replacement
你所需要的
    1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 1,3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 2,3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 3,3
      • Remove the top (button side) rubber cover using your hands.
      添加评论
    2. Cineyo BT-03 Device Page Button Replacement: 步骤 2 中的图像 1,2 Cineyo BT-03 Device Page Button Replacement: 步骤 2 中的图像 2,2
      • Flip over the device and remove the bottom rubber cover using your hands.
      添加评论
    3. Cineyo BT-03 Device Page Button Replacement: 步骤 3 中的图像 1,3 Cineyo BT-03 Device Page Button Replacement: 步骤 3 中的图像 2,3 Cineyo BT-03 Device Page Button Replacement: 步骤 3 中的图像 3,3
      • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
      添加评论
    4. Cineyo BT-03 Device Page Button Replacement: 步骤 4 中的图像 1,3 Cineyo BT-03 Device Page Button Replacement: 步骤 4 中的图像 2,3 Cineyo BT-03 Device Page Button Replacement: 步骤 4 中的图像 3,3
      • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
      • The cover should remain as one solid piece.
      询问修复机器人
      添加评论
    5. Cineyo BT-03 Device Page Button Replacement: 步骤 5 中的图像 1,1
      • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    6. Cineyo BT-03 Device Page Button Replacement: 步骤 6 中的图像 1,1
      • Gently pull apart the two sections of the device.
      添加评论
    1. Cineyo BT-03 Device Page Button Replacement, Button: 步骤 7 中的图像 1,2 Cineyo BT-03 Device Page Button Replacement, Button: 步骤 7 中的图像 2,2
      • With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
      询问修复机器人
      添加评论
    2. Cineyo BT-03 Device Page Button Replacement: 步骤 8 中的图像 1,2 Cineyo BT-03 Device Page Button Replacement: 步骤 8 中的图像 2,2
      • Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
      询问修复机器人
      添加评论
    3. Cineyo BT-03 Device Page Button Replacement: 步骤 9 中的图像 1,2 Cineyo BT-03 Device Page Button Replacement: 步骤 9 中的图像 2,2
      • Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Rene Klopf
于01/30/17注册
487 声望
创作了4篇指南
团队
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G3
5 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 55
总计 421
