跳转到主内容
加入维修社区 - 创建账户
Chromo Noria Touch Screen Replacement
你所需要的
    1. Chromo Noria Touch Screen Replacement, Back Panel: 步骤 1 中的图像 1,3 Chromo Noria Touch Screen Replacement, Back Panel: 步骤 1 中的图像 2,3 Chromo Noria Touch Screen Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
      • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
      询问修复机器人
      添加评论
    2. Chromo Noria Touch Screen Replacement: 步骤 2 中的图像 1,1
      • Carefully turn the device over.
      • Lay the back panel aside so you can see the device's parts.
      询问修复机器人
      添加评论
    1. Chromo Noria Touch Screen Replacement, Battery: 步骤 3 中的图像 1,3 Chromo Noria Touch Screen Replacement, Battery: 步骤 3 中的图像 2,3 Chromo Noria Touch Screen Replacement, Battery: 步骤 3 中的图像 3,3
      • Place your finger at the end of the tape closest to the battery.
      • Peel the tape towards the flex cables to free the battery wires.
      询问修复机器人
      添加评论
    2. Chromo Noria Touch Screen Replacement: 步骤 4 中的图像 1,3 Chromo Noria Touch Screen Replacement: 步骤 4 中的图像 2,3 Chromo Noria Touch Screen Replacement: 步骤 4 中的图像 3,3
      • Using the spudger tool, place the tool along an edge of the battery.
      • Be careful not to bend or break the battery! Batteries contain hazards materials.
      • Move the spudger around the edges of the battery to detach it from the tablet.
      询问修复机器人
      添加评论
    3. Chromo Noria Touch Screen Replacement: 步骤 5 中的图像 1,1
      • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
      • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
      • Remove the battery.
      询问修复机器人
      添加评论
    1. Chromo Noria Touch Screen Replacement, Camera: 步骤 6 中的图像 1,2 Chromo Noria Touch Screen Replacement, Camera: 步骤 6 中的图像 2,2
      • Carefully detach one side of the black tape from the board.
      询问修复机器人
      添加评论
    2. Chromo Noria Touch Screen Replacement: 步骤 7 中的图像 1,2 Chromo Noria Touch Screen Replacement: 步骤 7 中的图像 2,2
      • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
      • Now, the flexing cable is ready to be removed.
      询问修复机器人
      添加评论
    3. Chromo Noria Touch Screen Replacement: 步骤 8 中的图像 1,2 Chromo Noria Touch Screen Replacement: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Using a pair of tweezers, hold the flexing cable right below the black connector.
      • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
      询问修复机器人
      添加评论
    1. Chromo Noria Touch Screen Replacement, Speaker: 步骤 9 中的图像 1,1
      • Using your spudger tool, remove speaker from the backboard.
      询问修复机器人
      添加评论
    2. Chromo Noria Touch Screen Replacement: 步骤 10 中的图像 1,2 Chromo Noria Touch Screen Replacement: 步骤 10 中的图像 2,2
      • Using the spudger tool, detach the speaker from the back of the screen.
      询问修复机器人
      添加评论
    3. Chromo Noria Touch Screen Replacement: 步骤 11 中的图像 1,1
      • Using a Soldering Iron, desolder both wires from the motherboard.
      询问修复机器人
      添加评论
    1. Chromo Noria Touch Screen Replacement, Motherboard: 步骤 12 中的图像 1,2 Chromo Noria Touch Screen Replacement, Motherboard: 步骤 12 中的图像 2,2
      • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
      询问修复机器人
      添加评论
    2. Chromo Noria Touch Screen Replacement: 步骤 13 中的图像 1,1
      • Remove the three pieces of tap keeping the wires in place.
      询问修复机器人
      添加评论
    3. Chromo Noria Touch Screen Replacement: 步骤 14 中的图像 1,3 Chromo Noria Touch Screen Replacement: 步骤 14 中的图像 2,3 Chromo Noria Touch Screen Replacement: 步骤 14 中的图像 3,3
      • Place a spudger on the small black pins on either side of the flex cables.
      • Gently push the spudger towards the back of flex cables to unlock the flex cable.
      • Remove the flex cables from their insert.
      询问修复机器人
      添加评论
    4. Chromo Noria Touch Screen Replacement: 步骤 15 中的图像 1,1
      • Desolder the eight connections.
      询问修复机器人
      添加评论
    5. Chromo Noria Touch Screen Replacement: 步骤 16 中的图像 1,1
      • Lift the motherboard to remove.
      询问修复机器人
      添加评论
    1. Chromo Noria Touch Screen Replacement, Touch Screen: 步骤 17 中的图像 1,3 Chromo Noria Touch Screen Replacement, Touch Screen: 步骤 17 中的图像 2,3 Chromo Noria Touch Screen Replacement, Touch Screen: 步骤 17 中的图像 3,3
      • Apply downward pressure to each of the clips that hold the touchscreen to the plastic surround.
      • Careful to not apply so much pressure as to break the device! These hinges should move easily.
      • Work your way around the device in a clockwise motion as you progress.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Nick Rohn
于10/30/16注册
475 声望
创作了3篇指南
团队
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 613
