跳转到主内容
加入维修社区 - 创建账户
Chef's Choice M115 Motor Assembly Replacement
你所需要的
    1. Chef's Choice M115 Motor Assembly Replacement, Case: 步骤 1 中的图像 1,2 Chef's Choice M115 Motor Assembly Replacement, Case: 步骤 1 中的图像 2,2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      询问修复机器人
      添加评论
    2. Chef's Choice M115 Motor Assembly Replacement: 步骤 2 中的图像 1,1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      询问修复机器人
      添加评论
    3. Chef's Choice M115 Motor Assembly Replacement: 步骤 3 中的图像 1,1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      询问修复机器人
      添加评论
    4. Chef's Choice M115 Motor Assembly Replacement: 步骤 4 中的图像 1,1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      询问修复机器人
      添加评论
    1. Chef's Choice M115 Motor Assembly Replacement, Power Cord: 步骤 5 中的图像 1,2 Chef's Choice M115 Motor Assembly Replacement, Power Cord: 步骤 5 中的图像 2,2
      • Carefully lift the entire motor assembly out of the case.
      询问修复机器人
      添加评论
    2. Chef's Choice M115 Motor Assembly Replacement: 步骤 6 中的图像 1,1
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      询问修复机器人
      添加评论
    3. Chef's Choice M115 Motor Assembly Replacement: 步骤 7 中的图像 1,1
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      询问修复机器人
      添加评论
    1. Chef's Choice M115 Motor Assembly Replacement, Motor Assembly: 步骤 8 中的图像 1,1
      • Reconnect the wires of the new motor assembly with the power cord and reassemble the device.
      • If your replacement motor assembly does not come with grinding discs or linkage pins, refer to our guides below:
      • Grinding Discs Guide
      • Linkage Pins Guide
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G3
5 名成员
创作了60篇指南
2指南评论
Any idea what might be wrong when ... stones don't spin, but you can hear the motor is turned on? Sounds like what would happen if something was jammed and the shaft won't turn BUT I've checked and the disks spin freely when the motor is off. I'm not sure it's worth messing with unless someone can tell me what to check.
Dan M - 回复 分享
I’m having the same problem! I’m guessing that this problem (of the motor turning on but not spinning the wheels) is in fact the motor not working. Obviously this is an old comment, but if anyone else knows if this is true, please let me know.
Gretchen Ela - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 2,177
