跳转到主内容
Chef's Choice M115 Linkage Pins Replacement
你所需要的
  1. Chef's Choice M115 Linkage Pins Replacement, Case: 步骤 1 中的图像 1,2 Chef's Choice M115 Linkage Pins Replacement, Case: 步骤 1 中的图像 2,2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Linkage Pins Replacement: 步骤 2 中的图像 1,1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Linkage Pins Replacement: 步骤 3 中的图像 1,1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Linkage Pins Replacement: 步骤 4 中的图像 1,1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: 步骤 5 中的图像 1,1
    • Remove the motor and shaft assembly from the bottom of the case housing.
  6. Chef's Choice M115 Linkage Pins Replacement: 步骤 6 中的图像 1,2 Chef's Choice M115 Linkage Pins Replacement: 步骤 6 中的图像 2,2
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
结论
另外一个人完成了本指南。
James Herin
于10/27/15注册
128 声望
撰写一个指南
团队
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G3
5 名成员
创作了12篇指南
一条评论
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 1,785
