跳转到主内容
Canon Powershot SD550 Shutter Button Replacement
Ken Michael
Ken Michael3 其他贡献者
最后更新于 January 28, 2014
15分钟
简单
The shutter button is one of the most commonly used buttons on a camera. Therefore, it is also the most likely to break.
你所需要的
工具
  1. Canon Powershot SD550 Shutter Button Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Shutter Button Replacement: 步骤 2 中的图像 1,1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Shutter Button Replacement: 步骤 3 中的图像 1,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 3 中的图像 2,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 3 中的图像 3,3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Shutter Button Replacement: 步骤 4 中的图像 1,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 4 中的图像 2,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 4 中的图像 3,3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Shutter Button Replacement: 步骤 5 中的图像 1,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 5 中的图像 2,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 5 中的图像 3,3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Shutter Button Replacement: 步骤 6 中的图像 1,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 6 中的图像 2,3 Canon Powershot SD550 Shutter Button Replacement: 步骤 6 中的图像 3,3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 1,2 Canon Powershot SD550 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 2,2
    • Next, unscrew the .115 inch screw fastening the shutter button to the camera.
    • Now lift the button away from the camera, exposing the button board.
    • You have successfully removed the shutter button.
结论
Ken Michael
于04/17/11注册
1 声望
撰写一个指南
团队
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G23
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 1,571
