简介
If your Canon PowerShot SX620 HS has a display screen that is broken or malfunctioning, use this guide to replace the display screen.
The LCD screen is the large screen on the back of the camera that allows the user to frame photos, view images, change camera settings, and more. The screen is glass, so it could also crack easily if dropped. It could also go black if an electronic component inside the screen fails. In these situations, you will need to replace your screen using the process in this guide.
Make sure your device is powered off and your SD card is removed before performing this fix.
你所需要的
Open the battery door located on the bottom of the camera.
Push the orange tab until the battery springs upwards and out.
Remove the battery from the camera.
3等其他人完成本指南。
