跳转到主内容
Canon PowerShot SX60 HS Front Panel Replacement
Ethan Boone
Ethan Boone4 其他贡献者
最后更新于 August 15, 2019
5分钟
简单
To complete many of the repairs on your Canon PowerShot SX60 HS it is necessary to remove the front panel. This guide will walk you through the necessary steps to remove the front panel.
The front panel is designed to protect the more sensitive and electronic components of the device from some elements and minor damage.
Before beginning this guide, ensure that your device is powered off completely.
你所需要的
工具
  • iFixit Opening Tool
    iFixit Opening Tool
  • Nylon Tipped Tweezers
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
查看更多...
  1. Canon PowerShot SX60 HS Front Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Front Panel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX60 HS Front Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Front Panel Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX60 HS Front Panel Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Front Panel Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX60 HS Front Panel Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Front Panel Replacement, Front Panel: 步骤 5 中的图像 1,2 Canon PowerShot SX60 HS Front Panel Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
  6. Canon PowerShot SX60 HS Front Panel Replacement: 步骤 6 中的图像 1,3 Canon PowerShot SX60 HS Front Panel Replacement: 步骤 6 中的图像 2,3 Canon PowerShot SX60 HS Front Panel Replacement: 步骤 6 中的图像 3,3
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Front Panel Replacement: 步骤 7 中的图像 1,1
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 488
