Canon PowerShot SX520 HS LCD Screen Replacement
5 - 10 分钟
中等
缺少的步骤
简介
转到步骤 1Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
你所需要的
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
即将完成!
结论
