跳转到主内容
Canon PowerShot SD850 IS LCD Screen Replacement
Peter Tran
Peter Tran4 其他贡献者
最后更新于 December 14, 2017
20 - 30 分钟
中等
不一致的图片
动态照片拍摄
Use this repair guide to replace a broken LCD screen on your Canon PowerShot SD850 IS.
你所需要的
工具
  1. Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 步骤 1 中的图像 1,3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 步骤 1 中的图像 2,3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS LCD Screen Replacement, Case: 步骤 3 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement, Case: 步骤 3 中的图像 2,2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 5 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 5 中的图像 2,2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  10. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  11. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 11 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the two metal frames that hold the LCD panel in place.
  12. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 12 中的图像 1,1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  13. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 13 中的图像 1,1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  14. Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 14 中的图像 1,2 Canon PowerShot SD850 IS LCD Screen Replacement: 步骤 14 中的图像 2,2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
结论
另外一个人完成了本指南。
Peter Tran
于10/06/10注册
225 声望
创作了6篇指南
团队
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G7
6 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 4,223
