跳转到主内容
Canon PowerShot SD1000 Battery Replacement
Nick Tompkins
Nick Tompkins10 其他贡献者
最后更新于 January 5, 2021
1分钟
简单
Use this guide to replace the battery on your Canon PowerShot, model SD1000.
When the battery is starting to fail on your Canon PowerShot it may experience drastically shortened battery life or does not turn on at all. Replacing the faulty battery will remedy the problem and ensure that you are able to continue to use your camera as normal.
This guide will walk you through 4 quick and easy steps on how to change your SD1000 battery (A90mAh 3.7V Lithium-Ion).
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Canon PowerShot SD1000 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the camera over so the bottom faces you.
    • Slide the battery cover open.
  2. Canon PowerShot SD1000 Battery Replacement: 步骤 2 中的图像 1,1
    • The battery cover should push out.
    • Prop open the battery cover.
  3. Canon PowerShot SD1000 Battery Replacement: 步骤 3 中的图像 1,1
    • Let the battery cover open fully and rest as shown.
  4. Canon PowerShot SD1000 Battery Replacement: 步骤 4 中的图像 1,1
    • Flip the plastic lever holding the battery as shown.
    • Remove the battery.
结论
团队
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G18
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 33
总计 2,677
