跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A80 LCD Screen Replacement
你所需要的
    1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
      • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
      询问修复机器人
      添加评论
    2. Canon PowerShot A80 LCD Screen Replacement: 步骤 2 中的图像 1,2 Canon PowerShot A80 LCD Screen Replacement: 步骤 2 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
      • To access the second screw, rotate the screen 90° so that it faces upwards.
      询问修复机器人
      添加评论
    3. Canon PowerShot A80 LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon PowerShot A80 LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon PowerShot A80 LCD Screen Replacement: 步骤 3 中的图像 3,3
      • Gently remove the front and back covers from the screen.
      • Peel back the plastic circuit cover.
      询问修复机器人
      添加评论
    4. Canon PowerShot A80 LCD Screen Replacement: 步骤 4 中的图像 1,1
      • Pull the screen away from the base.
      • This will take some force, but remember to handle with care.
      • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
      询问修复机器人
      添加评论
    5. Canon PowerShot A80 LCD Screen Replacement: 步骤 5 中的图像 1,1
      • Unplug the ribbon cable connected to the circuit board latch.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
4等其他人完成本指南。
konrad
于01/11/11注册
220 声望
创作了3篇指南
团队
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G31
6 名成员
创作了18篇指南
2指南评论
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - 回复 分享
Do you know where can I find a replacement LCD over internet?
Paolo Gai - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 78
总计 5,094
