当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
Start from the battery compartment and remove the back cover.
Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Remove two 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Caution: Do not tug on the LCD screen. This will tear the ribbon connecting the LCD screen to the body of the camera.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Unscrew 2 3.35mm phillips head screws from the face of the green circuit board using a #00 phillips head screwdriver.
Caution: Do not tug on the circuit board. This will tear the ribbon connecting the circuit board to the body of the camera.
Release the black ribbon clamp using an iPod opening tool to lift it.
Remove the ribbon connecting the circuit board from the body of the camera using tweezers.
The SD card reader is attached to the back of the circuit board. The circuit board and SD card combination should be replaced.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
