跳转到主内容
Canon PowerShot A4000 IS Display Replacement
Ansley Gardner
Ansley Gardner3 其他贡献者
最后更新于 March 10, 2020
10分钟
中等
更好的介绍
你所需要的
工具
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot A4000 IS Display Replacement, Removing the Screws: 步骤 1 中的图像 1,2 Canon PowerShot A4000 IS Display Replacement, Removing the Screws: 步骤 1 中的图像 2,2
    • First remove the batteries and memory card.
    • Remove the screws for the back cover (circled in red) with a Phillips head screwdriver (PH000) .
  2. Canon PowerShot A4000 IS Display Replacement, Removing the Back Cover: 步骤 2 中的图像 1,1
    • The back cover can be gently pried off after the screws are removed.
  3. Canon PowerShot A4000 IS Display Replacement, Disconnecting the Screen Frame from the Camera: 步骤 3 中的图像 1,2 Canon PowerShot A4000 IS Display Replacement, Disconnecting the Screen Frame from the Camera: 步骤 3 中的图像 2,2
    • Remove the three screws outlined in the pictures.
  4. Canon PowerShot A4000 IS Display Replacement: 步骤 4 中的图像 1,2 Canon PowerShot A4000 IS Display Replacement: 步骤 4 中的图像 2,2
    • The ribbon for the screen is folded under the plate. Carefully unfold the ribbon by flipping the screen face down next to the camera.
    • Underneath the plate the connection between the camera and the ribbon can be viewed.
  5. Canon PowerShot A4000 IS Display Replacement, Disconnecting the Ribbon and Removing the Screen: 步骤 5 中的图像 1,1
    • The metal frame of the screen can be removed using a thin spatula or spudger. After the frame is removed the part of the ribbon connected to the screen is accessible.
结论
Ansley Gardner
于10/13/14注册
761 声望
创作了7篇指南
团队
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G3
3 名成员
创作了17篇指南
一条评论
Completely worthless repair guide! Do not try before reading below!
In Step 4, this guide neglects to mention at all if you raise the plate too high to get to the screen ribbon connector, you will DISCONNECT the ribbon connector “north” (above) it for all the controls and, apparently, power on/off. And if you disconnect this second connector, you are S.O.L. as there is no way to remove the plate completely to reconnect it (the ribbon has nearly zero length/play in it) and the ribbon/control board cannot be completely detached from the plate to give you more length/play as there is a THIRD ribbon connector between the plate and microphone from the control board that dives deep into the innards of the camera.
So because I wasn’t warned and lifted the plate a little too high, I disconnected the controls/power connector with no good way as an average person at home with limited tools or camera repair skills to reseat it, and now have a $20 new LCD screen in a camera that won’t turn on.
Thanks, fixit! >:(
sloe_mule - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 32
总计 1,197
