跳转到主内容
加入维修社区 - 创建账户
Canon PIXMA MP620B Scanner Light Replacement
你所需要的
    1. Canon PIXMA MP620B Scanner Light Replacement, Separate the scanner cover from the rest of the lid assembly: 步骤 1 中的图像 1,1
      • You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
      询问修复机器人
      添加评论
    2. Canon PIXMA MP620B Scanner Light Replacement, Lift the glass cover of the scanner and take out scanner light: 步骤 2 中的图像 1,1
      • After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
      询问修复机器人
      添加评论
    3. Canon PIXMA MP620B Scanner Light Replacement, Unplug the white wire from the scanner light assembly: 步骤 3 中的图像 1,1
      • Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G21
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 29
总计 3,032
