跳转到主内容
Canon EOS Rebel G Viewfinder Replacement
Kyle Reis
Kyle Reis5 其他贡献者
最后更新于 July 31, 2023
15 - 20 分钟
困难
This guide will teach you how to remove the viewfinder from your camera.
你所需要的
工具
查看更多...
  1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Viewfinder Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel G Viewfinder Replacement: 步骤 2 中的图像 2,2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Viewfinder Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel G Viewfinder Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel G Viewfinder Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Viewfinder Replacement, Top Panel: 步骤 4 中的图像 1,1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Viewfinder Replacement: 步骤 5 中的图像 1,1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Viewfinder Replacement: 步骤 6 中的图像 1,1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Viewfinder Replacement: 步骤 7 中的图像 1,3 Canon EOS Rebel G Viewfinder Replacement: 步骤 7 中的图像 2,3 Canon EOS Rebel G Viewfinder Replacement: 步骤 7 中的图像 3,3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: 步骤 8 中的图像 1,1
    • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
结论
Kyle Reis
于04/02/12注册
52 声望
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了36篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 3,111
