跳转到主内容
Canon EOS Rebel G Back Panel Latch Replacement
Zach
Zach7 其他贡献者
最后更新于 July 31, 2023
5 - 10 分钟
中等
This guide teaches how to to install the back panel latch on your camera.
你所需要的
配件
工具
  1. Canon EOS Rebel G Back Panel Latch Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Latch Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel G Back Panel Latch Replacement: 步骤 2 中的图像 2,2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Latch Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel G Back Panel Latch Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel G Back Panel Latch Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Latch Replacement, Back Panel Latch: 步骤 4 中的图像 1,1
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Canon EOS Rebel G Back Panel Latch Replacement: 步骤 5 中的图像 1,1
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Canon EOS Rebel G Back Panel Latch Replacement: 步骤 6 中的图像 1,1
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
结论
Zach
于04/04/12注册
46 声望
创作了8篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了36篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 2,728
