跳转到主内容
Canon EOS 60D Rubber grips Replacement
Eric D
Eric D2 其他贡献者
最后更新于 February 1, 2020
5 - 10 分钟
简单
社区贡献指南
The grips for the 60D come off easy, they just peel off. For many 60D owners, Canon already helped you by choosing a poor / defective adhesive for the first few batches of cameras shipped.
你所需要的
工具
  • Spudger
    Spudger
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: 步骤 1 中的图像 1,1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
结论
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10等其他人完成本指南。
Eric D
于11/13/12注册
1,362 声望
创作了5篇指南
1指南评论
Where can we get replacement grips?
Luke Lin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 12,182
