跳转到主内容
Canon ELPH Z3 Camera Battery  Replacement
Nathan Barros
Nathan Barros 另一个贡献者
最后更新于 February 19, 2020
30秒 - 2分钟
非常容易
Batteries are one of the most commonly replaced components in almost any device. Batteries are not designed to last forever and will run out of energy in time (dependent on usage of the device). In the event of your camera not powering on upon pressing the on/off button, one of the first components you should focus on is the battery. The battery is the most common issue when the device is not powering on and it is the easiest to fix. This guide will go through alll of the steps to show and explain how to replace the battery of the Canon ELPH Z3. It is a quick, safe, and easy process to follow that will not take much time.
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 1,3 Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 2,3 Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: 步骤 2 中的图像 1,2 Canon ELPH Z3 Camera Battery  Replacement: 步骤 2 中的图像 2,2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
结论
Nathan Barros
于10/18/16注册
1 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 867
