跳转到主内容
CHI Spin N Curl Rotating Curler Rotating Barrel Replacement
Annalise White
Annalise White4 其他贡献者
最后更新于 June 8, 2023
30分钟
中等
需要更好的图片
需要更多图片
缺少的步骤
Do you need to replace the barrel of your CHI Spin N Curl Rotating Curler? If so, this guide is for you. This guide will walk you threw the replacement process in eight steps. Make sure you have a 2.0 mm Flathead Screwdriver, Metal Spudger and a Phillips screwdriver for this guide.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 2 中的图像 1,1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 3 中的图像 1,2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 3 中的图像 2,2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 4 中的图像 1,2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 4 中的图像 2,2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 5 中的图像 1,3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 5 中的图像 2,3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 5 中的图像 3,3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Heating Element: 步骤 6 中的图像 1,1
    • After following steps to open the CHI Spin N Curl, locate the heating element.
    • Remove screws on both sides of the heating element.
    • Once screws have been removed, then remove the heating element component.
    • Replace heating element once the original has been removed.
  7. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Rotating Barrel: 步骤 7 中的图像 1,1
    • Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
    • Screws will be small and black.
  8. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 8 中的图像 1,2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: 步骤 8 中的图像 2,2
    • Remove all screws located near wires using a Phillips #00 screwdriver.
    • Once all surrounding screws have been removed, detach the rotating barrel.
    • Gently remove the rotating barrel and replace once removed.
结论
2等其他人完成本指南。
Annalise White
于10/26/22注册
530 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G7
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 35
总计 845
