跳转到主内容
CHI Spin N Curl Rotating Curler Motherboard Replacement
Annalise White
Annalise White4 其他贡献者
最后更新于 July 5, 2023
30 - 45 分钟
中等
缺少的步骤
Creating waves and curls in your hair is difficult and tiresome with normal products. The CHI Spin N Curl Rotating Curler makes creating waves and curls easy and efficient. If your curler no longer works it is worth the time to save money and repair it from home with just a few easy steps. This step by step process shows how to repair a CHI Spin N Curl Curler that no longer turns on. This is a safe and easy process that requires a replacement of the device's motherboard. These easy steps don’t require any advanced knowledge of electronics and include pictures to help guide along the way.
Before beginning this repair, be sure that your curler is unplugged from the power outlet and has cooled off it was used recently.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. CHI Spin N Curl Rotating Curler Motherboard Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 3 中的图像 1,2 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 4 中的图像 1,2 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 5 中的图像 1,3 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 5 中的图像 2,3 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 5 中的图像 3,3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Motherboard Replacement, Power Cord: 步骤 6 中的图像 1,1
  7. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 7 中的图像 1,1
  8. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 8 中的图像 1,2 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 8 中的图像 2,2
  9. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 9 中的图像 1,2 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 9 中的图像 2,2
  10. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 10 中的图像 1,3 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 10 中的图像 2,3 CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 10 中的图像 3,3
  11. CHI Spin N Curl Rotating Curler Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  12. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  13. CHI Spin N Curl Rotating Curler Motherboard Replacement: 步骤 13 中的图像 1,1
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
结论
Annalise White
于10/26/22注册
530 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G7
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 353
