跳转到主内容
Brother CS6000i Body Replacement
Ava Martinez
Ava Martinez4 其他贡献者
最后更新于 December 31, 2024
10分钟
简单
If your Brother CS6000i sewing machine is having any issues internally, it requires the body of the machine to be removed to repair any issue. This guide provides all the information on what screws to remove in order to open up the sewing machine.
This guide will act as a prerequisite to the majority of the Brother CS6000i guides.
Before beginning on this replacement guide, make sure that the Brother CS6000i is completely disconnected from any power source.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Brother CS6000i Body Replacement, Body: 步骤 1 中的图像 1,2 Brother CS6000i Body Replacement, Body: 步骤 1 中的图像 2,2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Body Replacement: 步骤 2 中的图像 1,2 Brother CS6000i Body Replacement: 步骤 2 中的图像 2,2
    • Pull the white cover off.
  3. Brother CS6000i Body Replacement: 步骤 3 中的图像 1,2 Brother CS6000i Body Replacement: 步骤 3 中的图像 2,2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Body Replacement: 步骤 4 中的图像 1,3 Brother CS6000i Body Replacement: 步骤 4 中的图像 2,3 Brother CS6000i Body Replacement: 步骤 4 中的图像 3,3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
结论
Ava Martinez
于10/31/24注册
433 声望
创作了4篇指南
团队
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024 的会员
CUESTA-KRYNEN-F24S20G1
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 68
总计 191
