跳转到主内容
Briggs and Stratton instart - Battery imbalance repair
Computerix
Computerix 另一个贡献者
最后更新于 September 23, 2024
1 - 3 小时
困难
社区贡献指南
If the green and red LEDs on the charger flash alternately there is a high probability of a battery imbalance. This usually occurs when the battery has not been charged for a long time and the individual cells have discharged differently. The charger cannot compensate for this imbalance. These instructions describe how the cells can be brought back to the same voltage.
你所需要的
配件
查看更多...
  1. Briggs and Stratton instart - Battery imbalance repair, Check charger LED: 步骤 1 中的图像 1,1
    • Plug the battery into the charger and check if the green and red LEDs on the charger flash alternately. If yes, there is a high probability of a battery imbalance and the following steps might solve the issue
  2. Briggs and Stratton instart - Battery imbalance repair, Open the battery pack: 步骤 2 中的图像 1,1
    • Open the battery by removing all 4 TR10 screws
    • The cover can be removed without much effort
  3. Briggs and Stratton instart - Battery imbalance repair, Measure cell voltage: 步骤 3 中的图像 1,1
    • Measure the voltage of all 3 individual battery cells
    • Cell1: BV+ - BV2
    • Cell2: BV2 - BV1
    • Cell3: BV1 - BN
    • If cells have different voltage (>0.1V) this indicates a battery imbalance
  4. Briggs and Stratton instart - Battery imbalance repair, Charge cells to same voltage: 步骤 4 中的图像 1,1
    • Charge each cell to the highest individual cell voltage (no need to fully charge all of them)
    • Set power supply to 4.1V and limit current to 750mA. 750mA is the standard charging current for a LGDAHB21865 cell. If the battery has different cell type, the datasheet needs to be checked first.
    • Important: Do not exceed cell type rated charging voltage or current. Refer datasheet.
    • Connect the power supply to the terminals of the individual cell and charge until terminal voltage reached. Make sure polarity is correct (positive to positive and negative to negative). Observe the charging procedure at all time.
    • Important: Individual cells are not protected against reversed polarity. Wrong polarity will kill the cell.
    • Note: If battery cell is not charging the cell might be dead. Don't continue charging and consider replacing the cells or recycle the battery.
    • At the end of the charging procedure verify each cell has same voltage using the multimeter (+/- 0.01V). Note that cell voltage provided on the power supply unit might not be the same when measured with the multimeter.
  5. Briggs and Stratton instart - Battery imbalance repair, Reassemble and charge battery: 步骤 5 中的图像 1,1
    • Reassemble the battery and charge it using the original charger
    • Battery is charging normally until fully charged
    • Note: If the issue occurs again during the charging process this would mean that the individual cell were charged at different rates. The cells aged differently and the internal resistance is not at a similar level anymore. Only replacing the cells would solve this issue. Consider contacting a re-cell service.
终点
另外一个人完成了本指南。
Computerix
于05/24/23注册
374 声望
创作了2篇指南
10条评论
Is it possible to replace the cells?
Thanks, David.
David - 回复
That's cerainly possible since the battery management does not lock the charger after an under discharge event (like some do). Replacement comes with some effort. Here I found a step by step disassembly guide. Challenges I see in finding a specific battery type with similar properties. Replacing the batteries would also require a spot welder. Avoid soldering the batteries to the terminals since the high temperature could permanently damage the cell. Always replace all the cells, not only individual ones.
If you are not firm with the topic consider buying a new one or contact a so called re-cell service.
My battery keeps working so far but in case a cell actually dies I will replace them and create an additional guide for this process.
Good luck and best regards,
Joel
Computerix -
Your solution worked. I charged the cells with two wires from phone charger..., cause it was the only thing ive got:) 5V 0.7A. For now its ok but I fear that the voltage of the cells will decrease individually again, and imbalance will return. Whole procedure took me 2 hours, so i will repeat it if needed.
Grzegorz Wasilewski - 回复
I'm glad it helped you. Your approach is fine. Charging with 5V should not do any harm as long as the actual battery voltage is monitored and does not exceed 4.1V (absolute max. 4.2V). There is a good chance that the problem will return in the future as the battery management is poorly designed and does not take into account the individual condition of the cells. As a result the cells tend to drift apart. The only option is to correct them from time to time. It is recommended to charge the battery to around 60 % before storing it for a longer period of time in order to avoid an undervoltage shutdown.
Computerix -
Good day and thanks for the instructions so far. My question is where to load the cells? Should I connect my charger to the steel clamps on the top, like the original charger does, or do I need to connect to the cells at the tin spots at the corners which are marked by the red lines on your picture? The steel clamps are marked with +, E, TH and -
Rob - 回复
添加评论
浏览统计数据:
过去 24 小时: 62
过去 7 天: 528
过去 30 天: 1,603
总计 8,721
