跳转到主内容
Braun 5514 Battery Replacement
Andrew Kluckhuhn
Andrew Kluckhuhn2 其他贡献者
最后更新于 January 23, 2025
30 - 45 分钟
中等
Over time, rechargeable batteries lose their ability to recharge. This guide shows you how to replace the battery in a Braun trimmer.
你所需要的
工具
查看更多...
  1. Braun 5514 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Battery Replacement: 步骤 2 中的图像 1,3 Braun 5514 Battery Replacement: 步骤 2 中的图像 2,3 Braun 5514 Battery Replacement: 步骤 2 中的图像 3,3
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four 7.0mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Battery Replacement: 步骤 4 中的图像 1,2 Braun 5514 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Battery Replacement: 步骤 5 中的图像 1,2 Braun 5514 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Battery Replacement: 步骤 6 中的图像 1,1
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Battery Replacement: 步骤 7 中的图像 1,2 Braun 5514 Battery Replacement: 步骤 7 中的图像 2,2
    • Desolder the four tabs connecting the batteries to the circuit board.
    • Repeat for the other side of the battery.
结论
27等其他人完成本指南。
Andrew Kluckhuhn
于07/05/18注册
1,087 声望
创作了2篇指南
团队
IUPUI, Team S2-G2, Harley Summer 2018 IUPUI, Team S2-G2, Harley Summer 2018 的会员
IUPUI-HARLEY-SU18S2G2
4 名成员
创作了8篇指南
12指南评论
What is the name/part nr. of the battery?
Casper Smit - 回复
Thanks!
This manual is applicable for the model 5516, too :-)
The battery type should be: AAA 1000 mAh; make sure, to choose batteries, that are prepared for soldering!!
Lucas B - 回复
Same goes for 5515.
Thanks for the guide :)
Yordan Chanev - 回复
Thanks, I was looking how to take apart 5513, similar enough, as far as the battery replacement goes, any rechargeable AAA battery should do. Batteries don’t like the heat from soldering iron, there are kits for welding batteries, another idea is to get cheap battery holder if you can fit it in.
Mariusz Lewicki - 回复
Does the 1.2V Ni-MH AAA 1000mAh battery work, have an older model MGK5280 ?
Thanks.
Jhon Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 119
过去 30 天: 653
总计 48,089
