跳转到主内容
Boss RC-1 Loop Station-Pedal Battery Replacement
Christopher Michaels
Christopher Michaels 另一个贡献者
最后更新于 June 7, 2021
5 - 10 分钟
简单
Use this guide if your Boss RC-1 Loop Station is not turning on (indicated by the red light at the top of the device). This guide will go through taking apart the device to access, remove, and replace the battery.
Disconnect all power sources. Remove any cables connected to the ports (also known as jacks) of the device. Never work on a device that is plugged into a power outlet.
你所需要的
工具
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 3 中的图像 1,2 Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 4 中的图像 1,1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 6 中的图像 1,1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
结论
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 66
总计 6,397
