跳转到主内容
加入维修社区 - 创建账户
Boosted Board 1st Generation Remote Battery Replacement
你所需要的
    1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 步骤 1 中的图像 1,3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 步骤 1 中的图像 2,3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: 步骤 1 中的图像 3,3
      • Before disassembling your remote, be sure it is powered off.
      • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
      添加评论
    2. Boosted Board 1st Generation Remote Battery Replacement: 步骤 2 中的图像 1,2 Boosted Board 1st Generation Remote Battery Replacement: 步骤 2 中的图像 2,2
      • Carefully separate the two halves of the casing by pulling them apart at the seam.
      • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
      询问修复机器人
      添加评论
    3. Boosted Board 1st Generation Remote Battery Replacement: 步骤 3 中的图像 1,3 Boosted Board 1st Generation Remote Battery Replacement: 步骤 3 中的图像 2,3 Boosted Board 1st Generation Remote Battery Replacement: 步骤 3 中的图像 3,3
      • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
      • Desolder the battery connections from the circuit board.
      • Replace the dead battery with a new 3.7 volt lithium polymer battery.
      • Refer here for more information how to desolder the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Kevin Manko
于10/06/16注册
164 声望
撰写一个指南
团队
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G7
4 名成员
创作了6篇指南
4指南评论
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - 回复 分享
hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please
Evgeny Bubnov - 回复 分享
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira - 回复 分享
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 74
总计 5,976
